woodbrains":1u56l54y said:
Jacob":1u56l54y said:
Yes, and how exactly do we pare slightly downhill when access can only be from one end?
Mike.
You ask me? I tell you!
... it was a rhetorical question, as the answer is, you can't.
Mike.
Actually Mike, you're assertion I believe is incorrect. I know this is not directly related to the original question, and the end purpose of the chiselling is different, also using different types of chisels ... but carvers carve against the grain on a fairly regular basis from what I've seen. I can't describe the technique in detail or with authority because I don't carve and have no interest in learning how; and almost any carving that's been required on any furniture I've worked on over the decades has generally been sub-contracted to someone with those skills-- a bit like subbing out upholstery jobs and passing on the charge to a client, along with a suitable mark-up, naturally! Slainte.
