Painting MDF advice without spraying
Chems
23 Apr 2008
A Wood Haven
I'm doing at a job at the mo and the client will be painting. I wanted to give them the details on how to paint the MR-MDF. I was going to suggest, PVA on all edges and sand down. Then use a foam roller and foam brush to do the painting. There is a little bit of beaded face frame so perhaps a little tricky. Going to recommend Dulux eggshell satin white. Does anyone else have anything better/more to add to this advice? Hoping for a nice clear satin white finish.
Can a clear coat be brushed on by hand at all?
PVA is a good glue but its really not designed to go under surface coatings- you'd be better off with a WB primer or better still a shellac based primer.
bear in mind that if your using an oil based paint it wont stay white for very long- so if pure white is spec'd better use a WB paint like sikkens rubbol BL satura
yes a clear coat can be brushed
Agree Zinsser as it sticks to anything is the best - but, since it's meths based, it will dissolve foam rollers. Dries almost too quickly for rolling. They also do a water-based one but I've not tried that.
The zinnser bullseye 123 is the water based version I thought?!
Having used both I much prefer the shellac based. Dries MUCH quicker
You'll find both in Selco.....although they are not cheap
I use an end grain sealer on mdf edges now, iirc kodrin wv456, but dont hold me to the numbers....about £10 a litre but much better than pva.
Paint pads seem to work very well on MDF- no brushmarks. I have only expereince of applying ordinary emulsion paint though
