Brans
Hello everyone,
Last year I built a garden table from scrap wood I found in company back yard and as you see on the picture below, I have sanded legs to 240, filled with P38 car body filler, sanded again, painted in three coats with woodies white paint and then put 3 coats of car clear lacquer. And as I can see it is still holding pretty good.
Now I am in a process of building two garden benches to match this table and after reading trough this forum i have couple doubts:
1 - Do I need to use the primer
2 - Do I need to use knotting solution or can I route knots 1mm and fill them
3 - What is a good external filler that can compensate all wood movements and won't crack (I used P38 car body filler from Halfords so far)
4 - Do I need to clean and fill line cracks that are full of pine resin
This is a photo of bench legs so far and they are also going to be white:
