Molynoox
Apologies if the following is just ridiculous over engineering for something simple, a slightly bad habit of mine unfortunately, but I can't decide what is best and looking for your thoughts.
So a friend has spotted my pergola lurking in my garden which I built last year and she has decided that she wants one too and has asked me to build one for her. Because of the specifics of her site, I have an interesting engineering problem, which I would like your thoughts on. It is concerning the methods I will use to hold the structure in place.
Proposed pergola design
Here are some pics of mine, the new one will be identical but only 4 metres wide, with 6 support posts, so kind of what you can see in the picture. Front and back posts are spaced 350mm apart. Sideways spacing 2 metres between posts
Spars in the picture are 2.1m, the spars on the new pergola will only be 1.7m. Probably Cedar, but may need to go for C24, which is a bit heavier.
Site
The site for the pergola is half onto a patio and half onto grass, so I will need to use a mixture of foundations to secure it in place.
Picture of the site below, support posts will be next to the fence with the spars overhanging the chairs. Posts shown in yellow, you can ignore the numbers for now, I explain that in a minute..
The paving slabs have been professionally laid and have what look like at least 50mm mortar underneath, and I am told there was some 'rubble' placed under there too. We might get more details as she is going to contact the guy that laid it, but for now we can assume 50mm mortar under the paving slabs, and some sort of MOT type 1 base.
So what's the big problem?
The added complication comes from the fact this is a 'cantilever pergola' (if such a term exists) and the rear support posts will be in tension and the front support posts will be in compression. So, combined with the mixture of patio and grass for ground, this actually gives me 4 types of fixing requirement:
The numbers 1,2,3,4 in the picture are the fixing types listed above
Proposed fixings
So, here are my thoughts on best method for each type:
For the type 1 and type 3 I am proposing to use 800mm self install groundscrews - I used those on my pergola and they are rock solid and perfect when going into soil. See pictures. Other than the cost I see no reason not to use these again (delivery is £45 and because I only want 2 groundscrews this becomes quite significant).
LINK
For type 2, the weight of the structure does most of the work and the fixings are mostly to stop sideways movement from the wind. I am proposing using concealed post bases from Simpson, combined with 175mm resin anchors, see pictures.
Concealed post fixing
Resin
For type 4, this is where it gets interesting, because the fixing has to resist the 'toppling' motion of the pergola, but I can't use a groundscrew because it is going into patio / concrete. This is where I am most keen to get your thoughts. There are 3 key options I can think of - and they may all be terrible ideas?
Option 4A, post base and resin anchor: same as with type2: concealed post base + resin anchors
Thoughts: would this be strong enough to resist the natural 'toppling' motion of the pergola? It wouldn't be taking all the force as the two posts on the far right would be fastened with groundscrews which I know wont move as they can cope with several hundred kilos of pull out force.
Option 4B, threaded bar, threaded insert: long (600mm?) M20 threaded bar, half of bar in post and half of bar in ground. Threaded inserts to attach bar to post. Resin to attach bar into ground.
Thoughts: my thinking here is that the long bar will resist the structure toppling because the natural rotation will be constrained by the long bar in the ground - the tip of the bar will move in an arc, but its a vertical hole, so it wont be able to. Does that make sense?
Dodgy sketch showing 4B and 4C options:
Option 4C, threaded bar, square flange: same as 4B but use a square metal plate / flange fastened to bottom of each post, with a M20 thread in the middle - the threaded bar would screw into the thread in the flange. Post would need boring out to accept the bar.
Thoughts: does such a plate exist - I think it probably does but I can t find it by searching?
I would appreciate any wisdom and opinions on this please![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Martin
![martin pergola 1.jpg martin pergola 1.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/117/117807-martin-pergola-1.jpg)
Site
![site and posts.jpg site and posts.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/117/117810-site-and-posts.jpg)
- Front post (in compression), into grass
- Front post (in compressio), into patio / concrete
- Rear Post (in tension) into grass
- Rear Post (in tension) into patio / concrete
Proposed fixings
LINK
![concealed post anchors.jpg concealed post anchors.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/117/117812-concealed-post-anchors.jpg)
Resin
![threaded bar options.jpg threaded bar options.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/117/117813-threaded-bar-options.jpg)
Martin
