Robbo3
In answer to a previous query about the Mini Gripper chuck from Craft Supplies, I stated that I used it to make oval bowls. So here are a couple, just to show you what this super little chuck will cope with.
- daft-question-t61493.html
Laburnum from a 4' long trunk of a neighbour's tree, stored upright for 6 or 7 years under the carport & dried using the carrier bag method ie. place a plastic carrier bag over each end. For the first month, remove, turn the carrier bags inside out & replace, daily. For the next three months, weekly. Then, whenever I remembered. I also upended the log on each change.
You will see that the bowl on the left is lobsided & thinner at one end. That's because I didn't level the top of the blank when I drilled the mounting hole for the Chuck. Then whilst hollowing with the Rolly Munro tool, took too large a bite due to a lapse in concentration.
Despite it's faults everyone who's seen it says they like its shape better. Seems that any future ones may have to be done on the tilt.
Regards
Robbo
Regards
Robbo
