Phil Pascoe
I've not used polyx before, so I've done a few test pieces (tonight) - some of you use it, so can you tell me if two coats are enough. That's what the instructions say, but it doesn't seem much.
Agreed...two very thin, brush applied coats is fine. De-nib 'twixt coats with some worn 320g. I use the matt version which I then polish with teak wax and a grey webrax to leave a slightly more satin finish - RobHarbo":3fscr2va said:Two thin coats is what I use.
Rod
Jake":3dhfx3xk said:The thinner version Osmo do is better for furniture - it doesn't do anything that varnish (or "danish oil" varnish) and an overcoat of wax doesn't do. But it is easier and quicker to apply without getting the thick wax layer the normal version is designed to leave (or desperately trying to misapply the finish to save it from itself).
