PeteG
After the laying out for the new P/T I decided to buy the Oneway to help with blade setting. I had seen them before but didn't really give it much thought until another member in a PM conversation recommended one. So yesterday I ordered one through Toolpost which was delivered by DPD bright and early this morning.
This isn't a review of the tool, as I've never worked within the accuracy that this provides, millimeters have always been just fine. I used the cast iron table on the bandsaw to set the Oneway up which takes but a minute a two, and as you can see in the first image both needles are set to Zero.
I then placed it on the outfeed table of the P/T...As you can see it's out by a smidgen, I then moved it around the bandsaw table again and got a
different reading every time. I best be careful not to breath to hard
I haven't used it to set the blades on the P/T yet, but it's a brilliant aid for setting the fence
