Sheffield Tony
Ghost of the disenchanted
I picked up a couple of old try squares the other day. A large one that I wanted, and a small one that came with it. both had the steel blade convex on both sides presumably from wear. The big one (branded "Comet") was otherwise OK, so with a bit of judicious filing and emery cloth, I have it back at 90 degrees and with a straight blade. The other one looks like scrap to me; the stock is not square in cross section, it has lost some of the washers from under the rivets, and is a tiny bit loose.
Does anyone bother to repair/restore these things ? Or are new ones cheap enough / easy enough to make that it is not worth the bother ? And is it possible, in a domestic setting, to renew that rather nice blue finish to the steel ?
