jimi43
I have for some time been in awe of craftsmen planemakers and none more so that the very early ones.
To me the "sardine tin" mitre shape is a vintage classic but alas...much sought after and usually expensive.
So it was with great glee that a non-descript one which had been rather overzealously cleaned appeared on FleaBay at the same time I happened on some birthday geld!
So...say hello to "Harry".....
This is the holder for the "Shaw & Co." iron I am having a bit of difficulty tracking down...other than that...there are no legible markings on the body.
Clearly, it is quite old...probably from the earlier part of the 19thC and ideal for flattening marquetry. I don't intend to get into a debate about marquetry/mitres and the primary use of these planes...suffice to say I call it an infill mitre as is the norm.
The infills are in wonderful condition and given the state of some of these planes...the patina might have been removed but thankfully not too badly....
I love the old steel bridges with the very plain half moon curve and reciprocal wedge cutout.
The very dainty scroll of the wedge compliments this beautifully.
Mouth damage is minimal and to be expected after a couple of hundred years but is restricted to the trailing edge...
The leading edge is absolutely pristine and rather tight...optimum in fact!
The front infill is stunning. Inside the throat is an attractive curve leading down to the mouth...
....this is probably my most favourite part of this plane.
The iron has seen a few year's use...was relatively flat on the face...nothing I couldn't deal with...and once sharpened...performs amazingly well...
I still have about another hour's work on the iron to get it like a razor but on the end grain that I tried...it worked fine.
The sides and sole are perfectly square and the dovetails and T&G mouth are so well made they are almost invisible...I had a real time trying believing that was how it was made but magnification confirmed it.
I think this is likely to be quite a user...certainly up there with the good ones!
If any of our resident experts know a bit more about this example...the age..etc...I would be most gratefully received!
ALFIE was most impressed!!!
Jimi & ALFIE!
Jimi & ALFIE!
