GraemeD
Guys, I've got myself a bit of a dilemma! I've just bought a used Creusen bench grinder, and I'm wanting to fit a pair of those amazing (as recommended by Philly) Norton 3X blue grind wheels to it.
So what's the problem? Well, Creusens have a 15mm diameter shaft. and the Norton grind wheels (being made in the US) have a 1" bore. The wheels (which I already have) come with a set of reduction bushes, but only to imperial sizes....not 15mm. Bushes are of course readily available from places like Axminster, but only down from 1 1/4" (or 32mm) bore which is the standard in Europe....not 1" as required here. I can't locate anything suitable anywhere!
Today I tried making a couple of wooden bushes to do the job, but even after several attempts I failed to get the internal bore accurate enough.....it was either out of centre, or oversize (or both!). I guess it's just my lack of skill on the wood lathe, though in my defence, the chuck and centres I have are not conducive to working to sub-millimetre tolerances. In this case I think it is pretty important to get this accurate, or the wheels will be off centre and cause vibration. Wooden bushes are probably not the way forwards here I fear.
I'm now getting desperate....does anyone have any ideas? Has anyone else successfully fitted these wheels to a Creusen?
Graeme
Graeme
