Arnold9801
I’m looking for some advice regarding my chimney. I took a gas flexi liner out as we want to put a solid fuel burner there’s instead.
The problem I have is that I have to widen the vermiculite/cement mix in the chimney that was around the gas fleximliner to accommodate a new 6 inch liner. It isn’t about as hard as dry clay or a week cement mix, but nevertheless is a swine to cut. I’ve hired a 6 inch core cutter but it was not working. Furthermore the six inch flexi needs a 7 inch hole to allow a smooth decent down the chimney.
I’m going to see if I could adapt a bike sprocket by attaching it Tom a threaded bar and use this as a form of router to see if that will cut a 7 inch housing for the liner. I’m not confident henceforth coming on here for some advice please.
For your info, I have to cut down from the removed clay pot through four foot of chimney. From there down I still the original granite chimney which is large enough for the 7 inch liner.
