Arnold9801
About 15 years ago we had a gas fire fitted resulting in them fitting a 4inch flexible flue down the chimney. We recently bought a log burner as we want to get rid of the gas fire. We have never been happy with it which is the reason for changing.
Ten years ago we had a new roof fitted on our Cornish Cottage so we decided that this was the best time to rebuild the original and dreadful chimney as the brickie could use the scaffolding that was there for the roofers.
To cut a long story short, the brickie cemented the liner all the way down through the clay pipe and then used vermiculite/cement from the clay pipe down through the lead skirt and to the base of the chimney which is level with the top of the roof, if that makes sense? From there down is the original chimney.
I eventually got the flue liner out, but now need to enlarge the hole to house the new 6 inch flue for the new fire.
To do this I was hoping I could hire a sds max 7inch cutter to go through the vermiculite/cement as this would make inserting the new liner much easier than a tight 6inch hole. Unfortunately 6 inch is the biggest cutter I can get.
Does anyone have any advice on how best to excavate the vermiculite/cement baring in mind I have to drill down approx 1Mt from the top of the chimney?
Any advice would be appreciated.
