Hi all,
I'm a fairly new woodworker so be gentle!
I've recently bought a flat, a conversion from an Edwardian vicarage. it has the most beautiful casement windows with fanlights (about 10 pairs), but they're not in great condition. There's quite a lot of rot and the previous owner did some bodge jobs which just haven't lasted.
We can't afford to get everything renovated right now (quotes are coming in at around 10K) so I want to do a little at a time, possibly trying to repair the simpler ones myself just to keep them going for long enough till we have the money, and paying per window sooner for the ones that are really gone.
I'll probably get started next year as we're coming to the winter, but as an experiment I did strip one of the windows down, see the attached pics (sorry - the forum will only let me attach really low quality images)
As you can see, this has been previously bodged and a lot of rot has got in. I want to fix this up enough at least so that it'll be ok for a year or two. The bottom left hand corner I've already done - I took out the rotten wood, hardened it, filled and sanded with two parter and it looks great.
The other vertical parts I'd like to fill in with but I'm not sure what to do with them - for now should I just bring them down to the piece at the bottom, making it continuous and flat at the front? Does it matter if there's a void behind them or is it just a matter of making sure there's a flat surface to keep the water out? The joiner doesn't seem to have connected them at all to the bottom part, which I think is a bit odd. Also I can't see how to put the putty back on to the bottom piece to hold the glass in as he's put a little curved piece on top of it (a bit hard to see in the photo).
Any advice would be really appreciated!
Louis
Louis
