CaptainBarnacles
Hi All,
First off, apologies to mods if this is in the wrong board, I wasn't sure if it should be here or in General Chat.
About a year ago I made a batch of oak sash windows for our old stone-built farm cottage that we are renovating. They were to replace uPVC windows that weren't old and there was nothing wrong with them, they just were utterly out of character for the house. With 13 windows to make I decided to do them in two batches so I made the first batch and installed them just before Christmas last year.
The windows were made using solid English oak with the sashes being side hung and opening outwards. I based my design on one that I saw in the Trend Modular Window System brochure (they call it Traditional Flush, here's a link to the PDF of their brochure http://www.trend-uk.com/en/AT/trend...php?file=bXdzX3RmX2Jyb2NodXJlX3BhZ2VzLnBkZg==) and worked on similar sized profiles.
The windows went together well and after glue up I fitted Aquamac 63 seal where the sash closed against the frame. The double glazing (4,14,6 Pilkington K) was installed using a soft rubber self-adhesive seal that was recommended specifically for wooden windows. The oak was treated with Sikkens Cetol as a base coat then a coat of Osmo UV protection was applied after about a week.
The frames were installed and any gaps sealed with expanding foam then pointed up with mortar and a silicone added where needed to seal the frames where they met oak cladding or lead etc. on the outside facade of the house.
Almost immediately we noticed that in the mornings the windows were streaming with condensation. The rooms are generally kept about 14-16 deg C overnight and we try to avoid creating excess moisture in the house (we have extractor fans in bathrooms and kitchen, wet clothing remains in the porch, laundered clothes are always dried outdoors, we don't have a tumble drier etc.....). We have tried leaving the windows slightly ajar (using the second notch of the handles) to see if the ventilation helps but it had very little effect. We thought at first that perhaps it was the old house drying out as it hadn't been properly heated since..... well, forever really! But after a year of dry and warmth, and having been very well ventilated over the warm summer the condensation is just as bad this winter as it was last year.
We have applied moisture barrier to all floors and walls before insulating them and dry lining all the walls. We don't have any gas heaters, just a small 5kW stove, the rest of the house being heated by an underfloor heating system. The house is usually warm and feels dry.
So one year on and despite trying to mop up the puddles of condensation that form on the window frames as best we can each morning, the oak is now starting to go black and I am feeling deflated that all my hard work appears to be rotting before my eyes. I am just about to complete the second batch of windows and if possible I don't want to make the same mistake again.
I just can't figure out why the condensation is forming as it is. On the remaining uPVC windows left in the house there is a bit of condensation forming but I would say it is only 5-10% of that which forms on the oak windows. I have asked a couple of builder friends but they couldn't come up with a decent explanation as to why it was happening. Additionally they both said that we appear to have done everything possible during the renovation of the house and the construction of the windows to avoid condensation problem - that just makes it more frustrating :?
Anyone got any suggestions?
Thanks,
Paul.
Thanks,
Paul.
