Newbie Question - Hose Size
I’m setting up a router table which has 63mm air ports. Should I use 63mm hose or should it be reduced in size? Thank you.
That rabbit hole is deep and full of terror.
Realistically, use the biggest you can on the assumption that you vac can take it. No point using 100mm on a vac with a 50mm inlet or that is going though a 50mm cyclone for example.
I have a router table with an outlet of 63/38 and a Trend T32 vacuum cleaner which has a 3m x 39mm OD hose with a hose spout of 35mm OD. Hope this is enough info. Thanks - Dave.
