matthewpetty
I have a heavy solid wood (with veneer surface) parsons coffee table (122Lx81Wx51H) that I have inherited and would like to repair. One leg was broken in transportation, and another is wobbly. Also some edges of the veneer are a bit rough.
The above photos on Flickr show what I have done to repair it temporarily. I would prefer to not compromise the clean upper lines of the table, but the solution with the brackets has not stopped the leg wobbling, because it doesn't get in to the original joint. What can I do to secure the legs?
Also, what should I do to fix the rough veneer edges?
I am a complete novice with little access to tools, no workshop, and little access to hardware here in Abu Dhabi. But I would like to try and fix this well. Grateful for any suggestions, tips or advice.
If I just have to find someone to fix it, what should I ask them to do?
Thanks,
Matthew
Thanks,
Matthew
