New SIP Cast Iron Sawbench
samlarsen
20 Jan 2004
Carlisle
Hi,
Just a quick note to anyone about to buy a new sawbench for around £500.
It seems SIP have just launched / are about to launch a new cast iron saw table. My local dealer has just received one so I had a quick look.
Features; large cast iron top (similar size to jet supersaw), very sturdy fence (fits left and right of blade), smooth rise and fall action, induction motor, weight over 100kg. 2 year warrantee. Overall it felt reasonable quality for the money. Made in ...... china of course.
I didn't have time to see it working.
Apologies if you all already know about this item. Maybe i'm the last in the world to hear about it.
cheers
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Sam
It is just like London buses. You wait for years and then along come three.
But wait, there's more than three.
Bosch (NB CAST ALLOY)
Fox
Jet
Record
Scheppach
SIP
Xcalibur
Apologies if I've missed any manufacturer, no make that importer, out.
How can SIP do it at less than 500?
Neil
Alf
22 Oct 2003
Up the proverbial creek
Neil, I was just thinking the self same thing. Never rains but it pours, eh? What about those Xcalibur ones? Do they count?
Cheers, Alf
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi all
There is obviously a great shake up taking place in the "heavier end" of woodworking machine manufacturing.
I think that with Norm and David having that tablesaw with it's cast iron table that it has started to drive the whole market place down the cast iron route.
Where do we go from here?
Neil
Signal
23 Dec 2002
Is it down to the lake I fear?
Sorry couldnt resist a bit of cacky old haircut 100 there lol :oops:
showing my age I guess
So sip have joined the fray as well this can only be a good thing as the more there are out there providing heavy lumps the better imho :wink:
Signal
Signal
23 Dec 2002
Neil
in comparison to James, Charllie and thomas I feel ancient
:wink:
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Signal
Signal":nqs71y14 said:
In comparison to James, Charllie and thomas I feel ancient :wink:
I'm keeping very quiet.
I've updated the Bosch tablesaw earlier in the thread as it is CAST ALLOY. Thanks for the information ALf.
Neil
Adam
10 Sep 2003
UK
I'm wondering at what point cast-iron on a cheap table results in sacrifices in other areas - e.g. cheaper motor to compensate. How flat are these tables for example? Is a warped cast-iron better than a flat one made of folded steel a.l.a Record? Or Aluminium? A cast iron table for under £500 is outstanding - I hope it's a general trend in cost reduction without a comprimise in quality but somehow....
Adam
A
Anonymous
Guest
Hi Adam
asleitch":3qiyiubt said:
I'm wondering at what point cast-iron on a cheap table results in sacrifices in other areas - e.g. cheaper motor to compensate. How flat are these tables for example? Is a warped cast-iron better than a flat one made of folded steel a.l.a Record? Or Aluminium? A cast iron table for under £500 is outstanding - I hope it's a general trend in cost reduction without a comprimise in quality but somehow.... Adam
It won't take long at all as the manufacturers obviously believe that if it's not cast iron or doesn't look like cast iron that it won't sell. Is the same thing happening in the US?
They will all be buying them from fairly similar, if not the same, factories located in (nma speak) faraway places. Following this to it's logical conclusion we will see fewer different tablesaws than before because, of the lower prices/competition, companies will not have the funds to be able to design their own saws.
Neil
Adam
10 Sep 2003
UK
But considering the "dark-grey" painted surface of the Record P/T - to look like cast iron - I think it's a safety hazard - the paint was textured - so would cause resistance to sliding wood across, and this in turn is far more dangerous IMHO. At what point does poorly machine cast iron become a similar liability - it's great when smooth - but if poorly finished - and you have to lean against the wood to push it across the surface - thats clearly opening the door for accidents?
Adam
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Adam
I've signed in this time. :oops:
I'd forgotten about the Record. IIRC, I thought that Record said, that the coating was supposed to help the wood move more easily over the bed.
As I said, I'm not sure of my facts but I recall reading something about it.
Neil
Adam
10 Sep 2003
UK
Hmm I smell something, and it comes from farmyards normally!
Makes it glide? I've been and had a look, and the guy showing it to me recommended sanding it all off to make it smoother LOL!
A
Anonymous
Guest
Hi Adam,
without seeing the Record planer, the explanation does actually ring true....
A rippling surface on a planer bed can help as it prevents the two smooth surfaces sticking to each other.
If you put two pieces of plate glass together and then try and slide them apart you'll see what I mean.
A rippling surface allows air to get under the work so that it will run over the bed smoother and with less user effort.
OK, I know a planer will put minute ridges into the surface of the work, but these are about 2-2.4 cuts per millimetre, so it's still smooth enough to make it suck to the bed.
Some cast iron machines have this, but whether a coat of textured paint will do the same on an aluminium one i'm not sure...
Andy
johnjin
11 Nov 2003
Whaplode Lincolnshire
Well I've got to agree with Andy here.
I've been machining on CNC milling machines for over thirty years and i can safely say that any largish area on a machine bed will always have been ribbed, scalloped, dimpled, or deformed in some other way for the very reason that Andy has said. All these undulations will only be about .05m/m deep but this is enough to stop it sticking. As for paint finish I know nothing about that and I would be very wary of it as over time some will rub off and some won't, leaving a surface that is not flat.
Adam
10 Sep 2003
UK
Ahh, I don't mean the ribbing you regularly see on cast iron stuff - that I can believe reduces surface resistance. I've seen it on thicknessers for example.
The Record P/T I was looking at just had a bad coat of dark grey paint, to make it "look" like cast iron - it wasn't on aluminium - it was on welded steel plate I think. Either way - it wasn't in any way beneficial to the user whatseover.
Adam
A
Anonymous
Guest
ok - I saw the SIP table saw in action this week-end , -- and will have it delivered this week - I needed to have it :D .
170 kg of seemingly good quality, 800 x 1200 cm cast iron table - can't wait to power it up in once the 16 amps feed is sorted
cheers
larry
Adam
10 Sep 2003
UK
Congrats, I'm sure you'll be really pleased with it.
Write a report for us eh? Do you have a digital camera?
Adam
