David C":18ugrbvm said:It has been suggested on the American forums that the close set chipbreaker at standard pitch produces a brighter surface than steep effective pitches. I have yet to try this experiment. However it seems that we have another weapon for impossible grain.
best wishes
David
Thinking about the geometry, are you not just simulating the burr edge on a good scraper blade ?David C":qz9nsuan said:Philly,
As you know, I am a great fan of high pitches and effective pitches.
best wishes
David
That's what I thought too.CHJ":2wf6sqwp said:.......
Yes I could do that, except non of my plane edges are that precise, they all have varying degrees of camber.Corneel":3b7hzbhn said:In theory you are right Jacob, but practically it proves not to be a problem at all. Nowadays I sharpen my irons freehand and the smoothers are straight enough. You use the light reflected from the face to determine how far you are. No need to use callipers, but meassuring once gives you an idea how much 0.2mm looks like. What I do is install the capiron on the blade, the screw tightened until the capiron is pressed flat, but not fully tight. Then I push the capiron forward, keeping the edge in the light. You can see very well how the silvery line gets smaller and smaller. Finally tighten the screw..........
Jacob":3slsarl4 said:This is where stropping (polishing) the face and bevel, has such a big effect on performance: friction is reduced so cutting gets easier, and it follows that wear is also reduced, which we all know happens in practice.
Jacob":2q1pto3f said:Yes I could do that, except non of my plane edges are that precise, they all have varying degrees of camber.
Yes I've got just one LV la bu smootherCorneel":w2ykm142 said:Jacob":w2ykm142 said:Yes I could do that, except non of my plane edges are that precise, they all have varying degrees of camber.
You only need one precisionsmoother.
I prefer a camberYou could put some effort in keeping that one straight.
If all else fails I use the LV plane. Then it's the ROS!......
What is your strategy to prevent or clean up tearout?
Chipping? I doubt it.bugbear":1nfqib7c said:...- highly polished (and hence sharp) edges are less prone to wear and chipping. .....
BugBear
Jacob":14ru765m said:Chipping? I doubt it.bugbear":14ru765m said:...- highly polished (and hence sharp) edges are less prone to wear and chipping. .....
BugBear
Stropping or polishing a narrow area behind the edge (2 to 5mm?) is not the same as polishing the whole face, or large areas of the face, as advocated by the polishing fraternity, for no apparent reason.
Oh and 'highly polished' (face and bevel) does not necessarily mean 'sharp', and vice versa.bugbear":3a0f5gp6 said:...- highly polished (and hence sharp) edges .....
BugBear
I haven't tried homeopathy, cannibalism, line dancing and zoophilia. Have you?David C":31gnuxqp said:Chas,
Yes, very close to scraper geometry.
Jacob says;
"not planing as we know it"
"I see nothing radically new"
"Setting a capiron less than 1 mm is not practical"
For someone who has clearly not tried the technique, he has a lot to say about it !
David Charlesworth
Register today and take advantage of membership benefits.
