Haggisterrier
New member
Hi looking for some information on buying a replacement shaft for my lathe, it's a Myford ml8 that i purchased about a month ago, it's the late model which came out as the advanced woodworker with the planer attachment and also the saw bench attachment plus a compound slide for metalwork, there's a small amount of play in the shaft along with movement between the drive pulley and shaft so suspect that some time in it life the 2 small grub screws in the pulley have been slack and therefore their not gripping as they should I've tried to tighten them but don't want to over do it incase I strip the thread in the aluminium pulley, any information or links too suppliers that may have the shaft as new or possibly new old stock would be much appreciated
