Myford ML8
OllyK
10 Jul 2006
Derbyshire
I've acquired a Myford ML8 wood turning lathe. I don't know much about turning and was wondering if this is worth keeping hold of or would I be better off selling it on and getting something a little more modern?
I guess the main use I have for a lathe is table / chair legs.
Alf":291gqblm said:
This should get you started on a decision with any luck. :)
Cheers, Alf
That's the fella, complete with the cabinet and bowl rests etc.
Metal turning to boot if I can source the bits - maybe it has potential!
Thanks!
Going by their metal working lathe which is THE standard for small workshops, it should be fine. You may have to hunt a bit ifor chucks if the headstock is threaded in Whitworth like the metalworking lathe as I believe the Asian imports don't use this.
If looking for a chuck for the ml8, Axminster do a back plate for that thread. It is their Thread code T03. See their catalogue section 18.07
Fred
