okeydokey
Hi
I have just bought a creamish coloured ML8.
A garage find (they were moving house and its it not been used for - well almost living memory - not a barn find but similar if you follow.
The tailstock has a broken casting (with the slotted bit missing) so the tail can't screw in or out.
It has a Planer attachment on the outboard side of the head and Circular saw on the inboard.
The current problem is that I would like to remove the circular saw attachment - the blade/guide/table all came off easily however the arbour that holds the saw blade is firmly stuck on the spindle.
Any ideas how to remove it please and would someone kindly confirm that its unscrews clockwise? I haven't tried anything serious yet so I wont have make it tighter.
The issue is how to lock the spindle - seems a bit dodgy to use the index pin as it might break off.
Thanks in advance for your comments and hopefully a cunning plan.
regards
regards
