PS to my earlier reply, The bearings a re huge angular contact bearins and they ar adjustable, On the outboard end you will see a collar threaded onto the spindle, remove the grub screw but do not lose the brass pad inth hole thaprotects the fine thread on the spindle, make sure the bearings are well oiled,never use grease and the gently screw up the collar until the end play on the spindle has just gone. Myford were very vague about this adjustment merely pointing out that too tight is bad. With this fee,is every thing, back off first to loose and then tighten with finger pressure whilst turning the spindle,once done fit the grub screw on its brass pad and you should be good to go.
