nicguthrie
I am, on the whole, about as far from an exhibitionist type as you can get - tending more toward being happy as a hermit if it were not for my wife winkling me out of my shell every day. However I promised I'd post a couple of pictures of the pens I've made so far, so here they are.
Bear in mind these are around the 5th to 10th items I've ever turned, so go easy on me... I deliberately took individual closeups so that any flaws etc are clear! Pics are not great, as all I have is a camera phone, and very little photography skill.
One thing has me stumped. On the "Cigar Pen" I used Cocobolo for the first time, and it's covered in dull areas in the CA finish. I've stripped it back to wood and recoated it, and they come back in the exact same places if not worse. These dull areas sand thru faster than the rest, as if the coating has vanished partway already... I just can't make head nor tail of it. That and the purple "Purse Pen are a wedding present that's getting very late indeed, so I'm a little annoyed that I can't seem to fix it after 3 sand-backs and recoats. I'm considering sanding it once more and coating it with shellawax instead - see if that stays put.
And the problem one...
Yay! My first photos on the forums!
Any constructive criticism is welcome, especially if you know what the dreaded dull bits are caused or cured by. I tried slower coating, thicker coating, different glues, and even BLO/CA combination - all to no avail.
Thanks.
Nic.
Thanks.
Nic.
