HudsonCarpentry
Hello
I have recently started building a router table, i have mounted the router and worked out everything other then the best way to do the fence.
I have thought of an L shaped fence that i could clamp in the position i wanted but this could take time getting the fence in the right place and wouldn't be the strongest solution.
I have also thought of fixing the fence at one end on a spindle and just rotating it at the right distance needed for the cut, but this way could prove to be not very accurate and cause problems?
Do any of you have any ideas?
Also this project was a challenge, the terms are i have to build it with out spending a penny. every thing used has to be scrap material and fixings??
Thank you
Thank you
