bugbear
I finally got round to making a case for my Charnley Forest stone;
car-boot-hone-t105298.html?hilit=charnley
(May last year, doesn't time fly!)
EDIT; link to the other thread, for convenience:
mounting-an-irrgular-hone-t105318.html
I took the last opportunity before casing it to flatten the upper surface. Despite seeing many reports saying CF is a hard Novaculite stone, it was soft, and as easy to flatten as a slate stone.
Onto the case. Following advice from an old book, I traced the outline of the stone, and drilled down to full stone-depth throughout, making no attempt to contour the hole (i.e. the hole had a flat bottom, but was stone shaped).
The end cheeks of the case were around 2/3", and the sides only 1/4"; the remaining timber under the stone was around 1/3" thick.
I mixed up plaster of paris according to information both from the 'net and the pack. I actually did a trial run with a small mix, so that I was sure of the setting rate and behaviour. It's most unlike concrete, in that you can continue to work it as it gradually thickens over about 10 minutes (*).
What could possibly go wrong?
I wasn't sure how to judge the amount of plaster needed, but I guessed and got it right. Fortunately. Success!
Sadly, when I checked a day later, the wooden case had DESTROYED itself. The water from the plaster had caused enough expansion to actually crack and split the wood.
So - has anyone successfully cased an irregular stone, and what did you do that was different to me?
The obvious thing to try would be to seal the hole (varnish or shellac), but there may be other issues to solve that I haven't anticipated.
So I would like to benefit from other people's mistakes and/or successes. All advice and knowledge welcomed.
BugBear
(* It is this property that is the key to setting a bubble vial in a traditional spirit level)
BugBear
