Hi all, I'm back with another project (and more questions...)
Objective:
I'll be cutting some objects out of wood for sports equipment (probably about 8mm thick - tho this spec is changeable within a few mm if needed). These will then be getting bashed about quite a lot! and I want them to last as is physically possible.
I want to know which material has the best resistance to breakage? I've been using oak, but remember reading somewhere that plywood is a better material as the inherent weaknesses along grain are re-enforced by the next sheet's opposing grain direction.
Questions:
is plywood better than boards of oak when working with around 8mm thickness.
is there something better than ply?
which type of ply would you use?
or -
if I'm totally wrong on this point, should I just continue using Oak?
In advance - many thanks,
Chris
Objective:
Questions:
or -
Chris
