duncanh
Something different for me again, and I mentioned the technique in another thread so thought I'd better post it...
click for larger image
Elm. 39cm x 6cm.
The texturing is done with the lathe stationary and the spindle locked. A circular wire brush in a drill is applied along the grain. This removes the soft wood and leaves the harder wood so the grain is still visible but gives a sand blasted effect. When the finish (Danish Oil) is applied this textured area ends up slightly darker and accentuates the effect.
The top side is worked in 3 steps...
1 - turn the rim and sand so that there are no tool marks - don't think that the texturing will hide any concentric lines that the tools may have left ,
2 - turn the centre. Doing this second should mean that you can create a definite step or separation between the textured and smooth areas.
3 - sand the centre section.
The bottom was worked similarly.
After sanding there will be a lot of dust in the textured pores and this needs removing before oil is applied. I used a small airbrush but I guess a brush would probably work.
Elm. 39cm x 6cm.
