duncanh
These have been turned over the last couple of months but I wait until I've got a few before taking photos...
click images for a larger version
Size: 11.5 cm diameter
This used to be a crown green (I think) ball. It's made from lignum vitae and the white insert on top is the original ivory that was in there. There should have been one in the bottom as well but I chipped it removing it when trying to find the original centres it was turned between. Underneath both centres were still there, which made it nice and easy to true up
Hollowing was done held in a contracting dovetail using a sorby scraper with the tungsten tip (normal scrapers appeared to put too much force on the wood and weren't much faster anyway, and a bowl gouge was useless as it built up oily residue from the wood on the bevel too quickly). And I drilled out as much of the inner as I could because hollowing was taking ages.
The bottom had a small void which was filled with brass powder and superglue.
After sanding to 2500 grit there was hardly any need of a finish, but I applied some wax anyway.
The original ball had a black (laquer?) finish on it which was hard to remove and you can see this in the cracks on the full size image. I quite like the effect though.
I have plenty more of the balls so will be making more. Does anyone know the legality of using or selling items like this that have old ivory in them?
And now for something different for me... lightpulls
click images for larger versions
The first 2 are made from recycled rosewood of some sort (I think) and about 12cm long - the wood was used as packing crates for some stone flags my dad bought which had been imported from India. It's pretty hard and takes an excellent finish but unfortunately I only have 3 lengths about 80cm long x 5cm square, and they are a bit cracked and have a few worm holes. They're juggling clubs in case you were wondering - one of my other hobbies is juggling.
The second 2 are lignum vitae without any finish. They're 6cm long
The third is beech. 8cm long.
more to follow next week...
