DiscoStu
I've got a slightly off the wall idea.
I am thinking of making a unit with an MFT style top. The unit will be in total 1500mm x 1000mm and around 800mm high.
My idea is to make two 1500mm x 500mm x 800mm units and hinge them together along one vertical edge and on the opposite edge I will have a clasp that will keep them together. The whole thing will be on casters. The idea is that you can un-clasp the two units and split the top in half so that you can use the inside of the unit for storage. I'm not sure if I'm explaining this well.
Anyway I would like to put an MFT style top on the whole thing so that I can use a track saw on it. So my real question is, does the underside of an MFT need to be hollow or can I just whack it on too of a sheet of MDF. I'm thinking mainly of the use of parf dogs here.
Also if I were to have a gap underneath what depth does it need to be for the use of the Festool clamp (the quick locking can type one)
Thanks in advance and apologies for my ramblings.
