MFT table CNCing
emlclcy
8 Jul 2010
basingstoke
hi, i'm building a MFT to sit on a pair of TOUGHBUILT C700 saw horses out of 19mm MDF. does anyone know a CNC company in hampshire that can machine the 20mm dog holes?
cheers
carl
Have you looked at RS CNC in Wrexham ?
If you can work with one or two standard size MFT replacement tops, their prices and delivery are pretty reasonable. I suspect cheaper than getting a CNC company to set up a custom job. Just a happy customer. I think I bought from them through ebay about 3 years back.
thanks for that, no point in reinventing the wheel! just emailed them
Are you looking at your MFT as a fixture or something that will eventually due to use need replacing because this may affect your decisions. If you have the tools you can make as many MFT's as you want and in any size you fancy otherwise you either pay for custom sizes or buy pre made.
I have purchased from CNC near wrexham and they are good products, for £40 you get an 1102 x 718 mm top in 18 mm MDF or £70 in 18mm Birch ply which may suit your needs or they do the jig Replacement Top Jigs | CNC Design but the Parf 2 system will set you back £200 so all depends on expected usage. The Parf system is easy to use and store, the RS CNC jig templates are ok but take up storage space as they are quiet large.
hi, it will eventually get replaced but i will be pretty careful with it so should last a log time. i have seen the parf 2 system, i'm not sure if it warrants getting one of those so will wait and see what CNC have to offer
Cnc Medite MR or Poplar ply at the moment but can make them out of anything really.
