Hi,
A few years ago I upgraded my Graduate lathe and also my Lorch Schmidt metal lathes adding a 3 phase inverter rated 1.1kw motor to each; both lathes are powered through a single Huanyang 2.2kw VFD. These 2.2kw VFD's run a single 1.1kw motor without problems. The VFD is mounted in a wooden ventilated enclosure to keep dust from it and one heavy duty 3 phase rotary switch for power plus a toggle switch for signal selects which lathe is to be run; only one lathe at a time can be run; the motors are twins allowing this to be done leaving the VFD parameters alone. The system has worked without any problems at all other than lots of initial problems associated by "cross talk" on the signal cable which I overcame by rerouting and using CAT6 cable. A bright warning light was added to let me know the VFD was powered up.
Anyway; a few months ago I bought two very old coach lamps from Rufforth Auto Jumble in York these requiring lots of work. The lamps were very rough and when I opened one up I found the lamp reflectors to be badly corroded and these reflectors refused to polish up so involved quite a bit of head scratching; I could have sprayed them silver but I'm a sucker for punishment always doing projects the hard way so wondered if I could make make new reflectors; to really complicate matters each lamp had three totally different reflectors meaning two of each style were needed?
I've been aware of metal spinning for over 50 years but never attempted it so I did lots of research. There are many YouTube videos covering metal spinning so I'll not go into a lot of detail; the spinning tool has to be extremely robust to withstand the force applied to its handle in order to give the necessary leverage; so much force in fact I cracked a rib which slowed me down a bit. With everything set up and the wooden pattern turned I destroyed half a dozen aluminium circles before making positive progress; it took about a week for me to grasp the basics but this wasn't full days by any means perhaps only two hours each session. I changed the profile of the bottom reflector to give more ventilation around the brass lamp holders
I can now not only spin metal (aluminium so far) but I successfully spun the required six reflectors much to my absolute delight. My best friend is secretary of his local woodturning club and he tells me members tend to "turn round and brown"? I'm adding this to say metal spinning can be done not only as in my case to spin reflectors but now I'm hoping to incorporate both metal spinning and woodturning into artistic turned items assuming the weather ever warms up enough.
I hope this is of interest.
Kind regards, Colin.
