Hi,
I have just bought second hand a Metabo T170 spindle moulder. Unfortunately it has a few bits missing and I am struggling to find parts because evidently it was made by Lurem and they are now out of business. I think I can make up most of the bits I need but most crucially I am after the fixing which holds the cutters down onto the shaft. There is two holes either side of a threaded hole on top of the shaft and I am assuming that there was originally some kind of washer with pins in it and a bolt which fed through the washer and held it on top of the shaft. If anyone can give me any information on this it would be very gratefully received. I am not sure if this is a common fixing found on a lot of spindle moulders or quite unique to Lurem. I am also after the length of extruded aluminium which forms the fence which sits on top of the sliding table.
Any info parts diagrams etc would be amazing.
Thanks,
Ryan
Thanks,
Ryan
