Mcluma
I will be building a large amount of shelving for holding up the collection of DVD’s around 3000. in our cinema room
The walls I will be attaching/placing it to will be 8mtr long and 5.2mtr long, the unit will be 4 shelves high with a plinth of 150mm (with rope backlighting)
I will be constructing shelves which are going to be around 1500mm long, at every 1500mm interval there will be a large bulkhead column of 400mm square (to display collector items etc) So on the 8mtr wall there will be 5 bulkhead columns and 4 series of shelves
on the short wall it will be shelves of 1200mm length with 4 bulkhead columns of 400mm square so total 5200mm
The units will be painted in a gun metal grey colour (dark)
What is best to use:
Plain MDF or MR MDF?
Then is it ok to use 18mm mdf for the shelves and carcass of the bulkhead column and then the back of the shelves in 12mm mdf?
DVD’s are not as heavy as books and the depth of the shelves will be around 180mm.
Is it best to still have a middle post to support the shelves from sagging?
Thanks for the advice
