OPJ
Hi all,
Well, I haven't been around here much for a long while but when I did come back not long ago, I was quietly pleased to see there is now a sub-forum for metalworking, as this might kind of tie-in with my day job!
I've spent the last couple of years making packing cases for a company with contracts in the aerospace and defence industry. It's barely woodwork as much as it's been 'nailing sheets of ply together' but in the last few months, I've been given an opportunity to step in to a brand-new department where we focusing on items like flight cases (where as before, we have only really made "boxes using flight case materials"...). We're talking about bespoke flight cases and, although I've never been much of a metalworker, I'm enjoying this.
Because of the nature of our business, the clients we supply and their specifications, I'm unable to show you too much about what we make but you can probably imagine what a flight case looks like (or Google it).
So, we've got a workbench made of a tube and bracket construction with a 25mm birch plywood top that we use for assembly. My prime concern is that the plywood won't last and it's already looking quite worn in places after finishing a large case this week (almost 8'x4' in size!). Over time, I can see swarf and metal deposits finding their way in to the scratches and crannies which could then have an effect on scratching and defacing our products (not good).
We want to keep the plywood top because it has four cut-outs (one in each corner - I must take a photo) that allow you to fit custom-made jigs for holding components for assembly (pipes, extrusion, etc). So, although I've not yet raised this issue with my superior, I'm thinking about some kind of scratch-resistant 'skin' that can be fitted directly over the ply...
Formica? Some kind of poly... Propylene? Lexan?
Google surprisingly doesn't thrown up many suggestions. One thought I had this morning was to cover it with 5mm of felt but then I would still be concerned about filings and swarf getting trapped within the weave and having to be blown out with compressed air (hazardous). I don't believe that lacquer would add anything practical.
If you have any suggestions of your own for a scratch-resistant material that won't damage any metal or plastic parts place on top, then it would be great to hear from you. Along with a photo of the bench, I'll see if I can share with you some of the 'toys' I now get to play with as well! ;-)
Hope you're all keeping well.
Olly
Olly
