prologus
I want to bend a 700mm * 2400 sheet of 6mm MDF along its length in order to attach it to a frame with shaped formers. The final shape calls for the "peak" of the curve to be 150mm above the edge of the MDF. I am pretty sure that glueing to the formers will put too much strain on the MDF and that the answer is to run a number of kerfs along the sheet and then glue to the formers. Have any of you tried this? How deep did you make the kerfs and how far apart did you set them?
Or is the answer to use 6mm ply?
