making a drll tidy - classic mistake
AndyBoyd
22 Nov 2002
Heiloo The Netherlands
I have just made a little double sided shelf to clamp to the pillar of my drill, in one side I made a hardwood plate in which I drilled a series if holes from 2.5 mm till 13 mm in 0.5 mm steps to hold my drills.
Now I seem to have made a classic mistake, the drills fit in their own holes with a interference fit (i.e they jam) is there a solution to this??? as moving each drill to the 0.5 mm bigger hole seems to sloppy a fit.
Here's hoping
This worked for me but might not for you so try first. On the reverse side drill out to 1/2mm oversize but not all the way through, this leaves an interference fit but not so much friction that you can't pull them out. Experiment first to get the right depth for you.
the wobblyness of the 0.5mm oversize holes is not just a function of the diameter but also the depth, a deeper hole won't feel so slack, problem is you are still left with a drill short of a hole for the 13mm bit. If you've got one, a taper reamer is an excellent tool to adjust the holes larger till you get a good fit, not everyone has one to hand though. Flocking the inside of the holes is an option too but messy. If you can, find someone with a complete set of drills, they will normally have the 0.1mm larger drills for clearance holes.
Aidan
You could buy a set of metalworkers drill bits. They come in 10ths of a mm so you could drill out to 0.1 or 0.2 of a mm bigger. Thats perhaps a bit expensive though.
Blimey Lord Nibbo, for 6.38 in the morning that is SOME lateral thinking!!
Thats my kinda solution!!
I like it!! I am gonna try that myself, Thanks!
Neil
Andy, if you have a cheap set of metal cutting drills or scrap ones, try grinding them with the web a little off centre. This will cause them to drill oversize as long as it is a fresh hole.
It's an attribute most people achieve with ease when they first try to sharpen a drill free hand.
