I think it might also depend a bit on how you plan to "grow" your setup. For instance if like me you add a bed extension in order to get outboard turning of larger objects, starting with the makers stand will make life a lot easier because the makers stand is pre drilled to allow extending the bed length or swing.. I have the bed extension for my Axi lathe. If you doubt you will go down that route I would not worry too much about bed height. If it is too high you can use duckboards or even a sheet of plywood to raise yourself in relation to the lathe. Likewise you can raise the lathe easily by bolting it on something such as flat steel on plywood.
