Aden30mm
1. I’m in a bit of a quandary, I need to move a new dust extractor into the workshop, primarily for dealing with lathe produced dust, but would like to have the option of using it for chop saw, small 10” bench saw, pillar drill, small sanding table and router table produced dust.
Caveat: I cannot site any dust vacuum machines outside of my garage workshop, due to nuisance factors
2. I’ve narrowed the choice down to:
Numatic NV750 Workshop Vacuum Extractor (equipment is equipped with 51mm hose only, noise level is 70dBA
Numatic NVD750-2 Workshop Vacuum Extractor, can take both 100mm , 32mm hose, but noise levels are 79dBA (considerable noise escalation, as for every additional 3dBA the noise doubles)
3. Questions
Does anyone use a 51mm hose for dust capture on lathe, by using a connection onto a large Mouth Dust Hood to be located close to the headstock? My perceptions are that a 100mm hose would be better.
If anyone uses the NVD750-2 are the noise levels tolerable? Again my perceptions are that due to the heat output of this machine putting into an enclosure within the workshop is a non starter.
4. Anyone using these machines I would welcome your help and advice on the above questions, also comments on their serviceability and durability would be well recieved.
Kind regards
Aden30mm
3. Questions
Kind regards
Aden30mm
