M8 thread T bolt source?
GeordieStew
19 Jun 2015
Jarrow
Can anyone recommend a supplier of M8 T bolts? Need about 4 of probably 50-60mm long and 4 of 80mm long.
In fact, a supplier of T bolts for 3/4 track would be handy in addition!
Sent from my SM-G920F using Tapatalk
I use coach bolts and file or grind a flat on each side of the round head to suit the track, cheap and readily available from Screwfix.
RDG sell M8 tee bolts to suit Myford tee slots:
https://www.rdgtools.co.uk/acatalog/TEE ... 32753.html
I'm not sure what size the heads are but I can measure mine if you wish.
edit: some googling suggests Myford tee slots are 5/32" at the wide bit, so perhaps too small for what you're after
2nd edit: that's 5/8", not 5/32".....
+1.
