Mcluma
Low block salt indicator for water softener
I have recently installed a whole house water softener system (with a separate kitchen non softened water tap and it excludes, outside tap & central heating filler)
All I can say I should have done it ages ago, its brilliant, no more scale.
However mine uses block salt and its very annoying that you frequently have to check for usage, and having the machine going empty and switching back to hard water would destroy all efforts undertaken to keep everything scale free
So is there a device that measures the salt block usage and gives some sort of optical alarm when the salt block reaches a certain level?
Rather then I start to build something, I hope that this was something that would have worried other people and a solution would be readily available
