Hi all....I have just bought a victorian semi detatched with the intent of modernising. Between the kitchen (back) and dining room (front) there is a chimney throughout the whole house. Next to the chimney (on both floors) is a single skin 4" wall (850mm wide) that divides the remainder of the room up to the door lining. I aim to remove this small section of wall at ground level. The joists upstairs are running perpendicular to the wall so one would assume that it is load bearing. However, the first floor wall is sat on top of the floorboards and at loft level there is latham plaster between the top of the wall and the roof joists. To me, this indicates that this wall has been built up at a later stage? Any thoughts would be appreciated!
Cheers, olliejim
Cheers, olliejim
