Lighting Tip
DiscoStu
24 Mar 2014
Lee on the Solent
I posted this is another thread but thought it might be worth sharing.
I find that sometimes I need some direct light on machines (Bandsaw and Pillar Dill). I use these £10 lights from Ikea:
I find they give a great directional light, clip on to my machines, stay where you bend them to and at £10 they don't break the bank!
I've had 2 of these, 1 over my grinder and 1 over my 12 inch sander for a couple of years now. Very directional and provide good light for my aging eyes. Next time I'm in ikea (groan), I shall pick up some more. Cheap as chips !
I use the same clip on Ikea light on my bandsaw and I use the similar Ikea model with the heavy base for use on my bench - both are very good.
There are two versions of that IKEA lamp, I think.
I've got one as a bedside lamp (it's the version with a heavy base), and that is 4W, and decently bright. I was keen on the clip on ones, but I think they're lower power output. Can't remember what, but it's worth double-checking if you intend them for a specific task.
The table lamp version, incidentally, is easily modified to fix onto things - there are two threaded bushes at the bottom of the gooseneck that take M3 screws. My pillar drill takes Edison screw conventional bulbs in a hard-to-get size nowadays (grrr!). i'll probably fit one of these when my stock finally runs out.
240v, 12w daylight LED panel light complete with converter to DC, about £7 on Ebay mounted on an articulated arm made from offcuts. Can be clamped or hung using the french cleat on the back.
    186.8 KB
I've got about four of those in the 'shop and more in the house...brilliant! :D - Rob
