Tony Spear":34hlndo9 said:
Cheshirechappie":34hlndo9 said:
the harder ones usually take longer to stabilise,
but the softer ones tend to move much more than hardwoods..........
One thing most people don't realise, or perhaps forget, is that the softwoods purchased from builder's merchants, DIY places, and the like are dried to a different target moisture content than hardwoods that are kiln dried for furniture type constructions: air dried hardwoods are a different story because wood air dried in the UK will seldom come down below about 18- 20% MC . Softwoods sold at these outlets are dried for the construction industry with a target MC of 20% ±2%. There are several reasons for this:
*Critically, 20% MC is the dry rot safe limit.
*If the wood is used in a residential building it will continue to dry out in situ, e.g., in the walls, studwork, and so on.
*And if it's used in uninsulated or poorly insulated commercial buildings its moisture content won't change too much from the 20%.
*There are more, but that will do to start with.
There are softwoods dried to a lower target MC suitable for furniture making, i.e., about 11- 12% MC in Europe (and about 7% ±2%MC in North America), but it's not available from the DIY and builder's merchant type outlets-- you need to go to a merchant that supplies this grade of wood.
As to tetsuiga's original question on whether or not you acclimatise your wood, it depends on its current MC, and its intended end use. If it's quite or very wet then acclimatising it is necessary for indoor furniture, but not necessary for outdoor artefacts. Very wet for internal furniture is something 14- 15% MC or greater. But if it's below that you can go ahead and make your furniture, but you'll need to make allowances for shrinkage in service, e.g., as cheshirechappie mentioned, such strategies as using buttons or expansion plates for table tops, allowing for panels to shrink within their framework, etc.
There's a lot more to know about allowing for wood movement in a wide range of end use situations, and even during construction than you can learn in a few quickly dashed off posts in a forum, particularly as the majority of respondents have very little understanding of the subject you asked about in particular, and timber technology in general. You can get an awful lot of bum steers if you're not careful, but that isn't the case in the already posted responses here. Probably your best bet if you really want to get to grips with the subject is to read a book on it. A good one is Understanding Wood by R Bruce Hoadley. Slainte.
