Letter Carving Question
MickCheese
29 Sep 2006
High Wycombe, Bucks
Would like some help.
Have bought the Chris Pye book and found it very good. I was just wondering if printing out the letters from my laser printer and sticking them onto a board is the way to go.
Problem is there are so many fonts to chose from I am a bit bewildered.
Before I start at the beginning, is anyone able to steer me towards a font and size that would be good for a total beginner.
Mick
xy mosian
21 Feb 2009
West Yorkshire
Mick,
I can't find the link at the moment, to my carved name board, but that is certainly they way I did it, and would again.
Size is a matter of from how far away the letters need to be read, long path or imediately in front of the board. The same goes for the font really if it cannot be read, easily, then for me there is little point. I think I used one called Celtic, I could well be wrong. The only other advice I would give is that not all layout programs allow the idividual letter spacings to be changed. Sometimes this is essential, especially if the leading character is a different size to the rest.
Have fun,
xy
Lons
14 Feb 2010
Northumberland
Hi Mick
What xy said!
Not sure I would stick letters to the timber but another method I've used is to transfer from the print with good old fashioned carbon paper. Works a treat.
I have a useful publication on pdf. Send me a pm if you're interested.
Bob
Cheshirechappie
30 Jan 2012
Cheshire
I haven't tried letter-cutting (yet!) but I did stick a template to a piece of wood when making a saw-handle recently, using spray adhesive. From that experience, I'd agree with Lons - don't do it. The template stuck fine, but cleaning it off later was not easy. Sandpaper just clogged. A cabinet scraper worked best in the end, but the glue-stains went quite deep. I've not tried the carbon paper method, but I sure will next time....
xy mosian
21 Feb 2009
West Yorkshire
I agree about the glue, I seem to remember using Scotch glue, fairly thin. Carbon paper sounds good, the last I bought was from Staples. Fortunately the assistant new what I was talking about, pick an older member of staff. :)
xy
MickCheese
29 Sep 2006
High Wycombe, Bucks
Thanks for the help. Tried a few letters and made a bit of a mess. Trying to run before I can walk at the moment so back to basics.
Bob you have a PM for the PDF.
Mick
katellwood
2 Jan 2007
Near Dartford, Kent
This is my experience
Works a treat
Stick down (I either use superglue or if more time PVA) then after carving scrape off with a cabinet scraper I used a stanley 80
MickCheese
29 Sep 2006
High Wycombe, Bucks
katellwood
Those letters look really crisp and perfect, it was looking at your original thread and others that made me decide I have to try it.
Just need to find the time to practice.
Mick
bugbear
16 Jul 2004
North Suffolk
Mick
The Chris Pye book (very good, as you say) appears to pre date laser printers, since he doesn't even tell you NOT to do it, but he does mention Letra Set.
The only down side I can see to a glued down drawing is that it prevents you reading the grain pattern for the cuts. Perhaps (thinking aloud) a diagram on overhead sheets (mylar) would be ideal?
BugBear
RogerM
4 Mar 2006
Devon
Mick
Sometimes the obvious is the way to go. For a beginner (that includes me), either "Roman", or something derived from "Roman" like "Felix Titling" or "Perpetua" make "carving friendly" letters. In my very limited experience I have just played around with the letters in MS Word, using something reasonably large like 160 point, and then on the "font tab" going to "effects" and ticking "Outline" so that you get an image of the outline of the letter rather than a solid figure. I don't like sticking the paper to the wood for the reasons already mentioned, but copy it using carbon paper. You'll also need to hand draw the ends of the serifs to remove the square look that the computer printed letters give you.
custard
20 Aug 2008
Hampshire
Works a treat
Looks great! =D> But instead of "KLT" show us "QRS"! #-o
Charlie Woody
10 Dec 2010
West Devon
Just saw this and decided to play around with Word on my laptop to see what fonts I could find etc. I can find most of the fonts that Roger M suggested but not the size of 160, the largest available seems to be 72. This seems to be too small. No doubt there is a way around this but I cannot work it out - any suggestions please?
marcros
11 Feb 2011
Leeds
Charlie,
On the version of word that I have at work, next to the font box is the drop down size box. As you say, it ges to 72. Next to that is an increase text size button with an "A" and a tiny up arrow. This makes the text bigger. If you keep pressing it, it will go larger than the 72.
HTH
Mark
katellwood
2 Jan 2007
Near Dartford, Kent
custard":3nl2ilc6 said:
Works a treat
Can't show you Q or S
but how about this (however in my experience J can be the most challenging)
gasman
14 Nov 2006
Near Oxford
Easier than glueing it on - just print your chosen font (I like Calibri but sometimes use a serfed font like Times New Roman) onto sticky labels - then cut out the lettering with a scalpel and then carve your letters. Works a treat
Regards from Oxford
Mark
