RogerS":3q44v5mz said:
Don't agree with Eric re PTFE tape. It's always worked well for me. Trying to get the olive off - especially if the pipe has been deformed - is a recipe for disaster.
Re 'shouldn't have a DHW header tank'...you can get combi's designed for vented systems now.
In the house I have now, I have dealt with three leaks caused by PTFE tape incorrectly applied to compression fittings (by other people). It is incorrect use and will cause premature failure if the pipe is subjected to movement, such as temperature expansion/contraction.
If the pipe has been waisted because of over tightening, you won't get a reliable seal unless you replace it.
Steven":3q44v5mz said:
Also how often should you expect to top up the CH system, I filled it to 1.5bar about 3 weeks ago and it is down to 1.1 today.
I'm with Paul on this one - you have a leak somewhere.
It's possible your pressure relief valve is leaking. It's on/near the boiler, often with a red plastic cap, and it vents to the outside air, usually through a 15mm pipe. Look for drips. My Vaillant ( :evil: ) has the thing mounted upside down, in such a way that the stub of pipe going to it fills with rubbish, which then stops the valve from sealing properly if it's ever opened, for example to drain down the system to do work on it.
The other boiler favourite is the 3-way diverter valve that does the DHW heating. They can be refurbished/repaired/replaced, but it needs a specialist (you're not supposed to work on stuff inside the boiler if you're not 'competent' in the terms of the regulations).
There is an expansion vessel, usually inside the boiler on smaller systems, that allows the water in the CH to expand when it heats up, instead of the pressure fluctuating wildly. These sometimes lose pressure (there is a Shraeder "tyre" valve on them usually). Setting the correct cold pressure is a job for a plumber, but if it's lost pressure and you fill the system, the pressure
will fluctuate wildly, as the expansion vessel fills too and there's insufficient space for hot water to expand into. In that case, it usually goes up when the system is hot and down again when it's off (CH, not the DHW mode on its own). They have an internal diaphragm to keep water and air separate: this occasionally perishes, but usually it just goes down over time like an unattended tyre and a simple pump-up to whatever the right pressure is sorts it out (job for a plumber, but should only take minutes really).
If not in/near the boiler, look for crusting/leaking around radiator fittings (most common problem). If you're losing 0.4 bar over that time, it's not a tiny leak, so you ought to be able to see it.
To be honest, it does sound like you need a pro to take a long careful look at the system.
