Laminate deign - any suggestions?
stuckinthemud
17 Jun 2019
Caerphilly
I want to laminate a structural L-shape beam using a central core and face plates. Each “arm” is 20” x 3”x2”. It will be supporting 75kg, and varnished not painted. It will be clearly visible and outdoors. Fancy joints or plain, there are so many options for joining the arms I’m a bit bewildered. Any suggestions?
Not sure what you're after here. A sketch might help.
If it’s a properly laminated structure using, say, 10 x 5mm laminas, formed to produce a curved right angled bend, then it might support 75kg. However if it's basically a large bracket made of 2off 3x2's then it's going to need a brace or maybe a steel reinforcement hidden in the joint.
Brian
Recumbent bike. Rough sketch of where I am at the moment. Still very early days at the moment. The joint in question is the boom to upright. The drawing shows a small “knee” to reinforce the joint. I would like to stay with all wood construction but metal or carbon fibre straps are not completely out of the question
My only insight is that it's going to be all about grain direction, but I guess you know that! So for the sake of brevity, if the joint turns through 90deg, then some of the structure will be at 45 deg to act as a web. And how you visualise the stresses should determine the size & shape of the joint.
Nothing like a challenge to keep the nodules sparkling!
I was once called on to replicate some ash framing members for a Morgan car - the angles curves and twists were interesting to make but as a purely wooden structure it was junk, with short grain at joints - but in its entirety it was a composite together with the screwed on aluminium body panels ...
