Lonsdale73
I bought one of these a little while back, the metric version with 5mm bit and a load of 5mm shelf pins. After drilling a whole load of holes I was a bit disappointed to find the holes were a fraction too big for the pins so they kept falling out. I assumed it was me doing something wrong so popped the jig in a drawer and promptly forgot about it.
Last month I started building a cabinet that would require a shelf so dug out the jig. Before ploughing ahead, I tested the jig on a piece of scrap. I clamped everything down to make sure nothing moved and kept the drill as perpendicular as was humanly possible to do but still the hole was a bit too big. Since buying the jig I've gone on to buy some digital calipers so I measured the whole hole and it was a shade over 6mm, nearer to the imperial 1/4" model. As a check, I drilled another hole with a known 5mm bit et voila, pins fit as they should. I checked the packaging which did clearly state it came with a 5mm drill bit. Checking the online site I purchased mine from, I saw they - and subsequently a number of other retailers - invariably describing it as "supplied with a 5mm (1/4") bit". I found some sites listing just the drill bit, similarly described. Now to me, 5mm is NOT 1/4", in this context not even close. So I contacted Kreg, explained the situation and asked confirmation of part number for the 5mm drill bit to ensure I didn't end up with another clearly 1/4" bit. Today UPS delivered a genuine Kreg 5mm bit all the way from the States with an apology for the inconvenience of receiving the wrong bit in the first place. Say what you like about the Americans but you can't fault their customer service.
And I've now tried the bit, definitely 5mm, pins fit great! So huge well done to Kreg.
