GeordieTurner
Hi, I have just inherited a 1983 Kity K5 Combination table. Everything works well and looks good, however the belt is worn and needs replacing. I measured it at 820mm x 15mm, does anyone know where I can get these belts and would a 20mm be better as it is flat and slides on and off the spindles according to the tool being used so width does not seem critical? Also does anyone know the saw blade size both diameter and centre? Many thanks, Richard
