chaoticbob
I've had a request from a forum member to make a new handwheel for a Kity 419. He's sent me the knackered wheel:
and a pic of the spindle which it fits:
Because he had the machine second-hand complete with badgered wheel he can't be sure about how it's meant to work. It seems that the handle is bored 12mm to fit the bit on the end of the spindle, and it's secured on that by grub screws - it looks from the second pic that the screws are misplaced and have bitten into the recess (does that have a function?) which can't be right. It's clear that a previous owner has tried to fix the wheel (hence that weird brass bit) but with limited success.
I'm assuming that the recess in the handle bore is there to accommodate the return spring and is necessary. If any kind soul with a working mechanism can help out with more info I'd be grateful. From what I've read failure of the handwheel gear is a common problem with an otherwise solid machine. When it's sorted I'll post a WIP with dimensions if there is any interest.
Bob.
Bob.
