i have a kity 419 table saw the blade tilt lock keeps slipping any advise
D dhm Member Joined 24 Feb 2012 Messages 6 Reaction score 0 Location kendal 24 Feb 2012 #1 i have a kity 419 table saw the blade tilt lock keeps slipping any advise
Racers Established Member Joined 22 Apr 2005 Messages 9,172 Reaction score 127 24 Feb 2012 #2 Hi, I have a Bestcombi 2000 that had the same problem, in the far end of the shaft is a nut it needs tightening a bit, I think I put a extra nut on to lock things in place. Pete
jasonB Established Member Joined 26 Nov 2004 Messages 5,044 Reaction score 2 Location Surrey 24 Feb 2012 #3 Yep as said there is a nyloc nut on the end of the rod, just wants nipping up a bit. J
D dhm Member Joined 24 Feb 2012 Messages 6 Reaction score 0 Location kendal 26 Feb 2012 #4 thank you will try this tip
D dhm Member Joined 24 Feb 2012 Messages 6 Reaction score 0 Location kendal 12 Feb 2014 #5 is there a way to improve the rise and fall /tilt handle .the plastic gears have stripped on mine
stuartpaul Established Member Joined 11 Feb 2003 Messages 1,062 Reaction score 59 Location Somerset 12 Feb 2014 #6 dhm":2necqc7r said: is there a way to improve the rise and fall /tilt handle .the plastic gears have stripped on mine Click to expand... I had exactly the same problem and it caused me many and issue trying to set the blade vertical. I believe NMA who used to be the main distributors upgraded to a handle with brass teeth? Worth a Google?
D dhm Member Joined 24 Feb 2012 Messages 6 Reaction score 0 Location kendal 13 Feb 2014 #7 tried nma same plastic gears nearly £40 I vaguely remember some other solution [? Viking john] but I cant find the posted comment
